Maximum number of Maintenance End Points added for this platform, can not add more. Since the MEP is tied to a ring, the ring must be disabled if the MEP cannot be installed.
Delete one or more rings, or delete one or more Maintenance End Points so another can be added.
Error
Maximum number of Maintenance End Points exceeded for this platform when adding MEP ID %mep%. Disabling ring %ring%
| Name | Type |
| ring | String |
| mep | uInt32 |
